Pump replacement question(s)
tmdry
Bill Martins
I have a Teel pump model 2P411C, 1725 RPM's.
http://www.grainger.com/Grainger/TEEL-Bronze-Plunger-Pump-2P411
I tried looking up for a rebuild kit for it and or parts and can't find it online, Grainger says they no longer carry it (not sure if the pump is still sold or not).
When looking for a replacement pump, should I stick to the same RPM's or should I look for something specific so it will be a direct fit for my TNT? I want it to be a direct fit with my pulleys/belts setup.
Thanks,
Bill
K
K P
You can use whatever pump you want as long it mounts.Looks like yours is on rails and that can be used on many.If you do not want to remove the smaller pulley from the drive,then yes it has to have the same specs as the old one.
Bill;
The pump you have is a Hypro model.
It is only a 2 plunger model.
What brand TM is that ?
I think we have the seals for that model.
If it is several years old,
I would look at upgrading to a 3-Plunger pump system.
