KevinD
Why does mixing O2 prespray and Quat a lot together in the hydroforce gel up, curdle , clog the sprayer and make a sticky mess for me.
I have seen posts of using it combined.
KevinD said:Why does mixing O2 prespray and Quat a lot together in the hydroforce gel up, curdle , clog the sprayer and make a sticky mess for me.
Leslie Judson Jones said:When I suggest people add Quat to the O2 it is for pet stain and odor combination. By mixing the two for this situation, you have the prespray that will remove the stain, plus it has high disenfectant properties, plus by adding the Quat it increases the effectiveness of removing the odor completely.
So look at QuatALot like this...for every ounce of Quat-A-Lot you add to your solution, it's like adding 4 - 8 ounces of a comparable product. So addressing your issue about mixing it in the HydroForce sprayer, maybe you just added more Quat-A-Lot than needed. This is just a guess.
If anyone is having a problem with my products, feel free to call me and I will replace the products if necessary. This is the first time I have heard of this happening.
THANKS
LES
Greenie said:ok...a little strong.
you got me puzzled, I'm gonna go out right now and mix some up at your ratio, and see what happens.
OK, I have a brew of your mix in a HF jug, looks good as of now, gonna let it sit overnight and inspect in the am, I can take pics if anythign looks funky.
