Question about my Butler system
Jtuseo
I have 1994 Butler system. There is a ball valve to mix the hot and cold water. Can I leave this valve closed so it is only hot water running through the system or should I leave it cracked a bit to let some cold water in as well. If I leave it open I do not maintain heat. when it was closed it stayed hot.
Thanks
Johnny 9WG
Brian L
Brian L
The only time I open the valve is when I am cooling down the solution hose before I reel it in. I run water through the vac hose to rinse it out at the same time.
E
Eric Scofield
John close the valve to hot, take off the handle, and throw it away.
Its a Butler, it only gets 195. :D
I only turn the heat down to wash my hands.
