Question for the truckmount gurus....
MerCrewser
Prochem machine with a pvc dump valve. If I replace with a more robust metal (bronze?) valve, with the dissimilar metals cause electrolosis issues in my aluminum waste tank? PVC valves are always seizing up and breaking....
don worry...yor aluminum waste tank will be toast in five years anyway...no madder what!
John Olson
John Olson
You'll be fine. What I see eating up waste tanks is people not flushing them out. Paper Clips, LOOSE CHANGE,Staples,Iron (dirt contains iron in case you didn't know) these things combines with the high akaline and acids that never get flushed is what eats waste tanks. Ask Vince Feehan how many waste tanks he has gone through on his Prochems....I bet ya a buck I can answer that without ever asking him.
John Watson
I used a piece of hose and 2 screw clamps on the PVC drain pipe, switched to a guillatine type valve. Just make sure to back suck with blower when through draining to suck out any debree that will cause valve to drip. Getting ready to change mine, only been there over 6 years!!!!!
Bob Savage
Bob Savage
Not true.
I have an aluminum waste tank that is 24 years old, and still going strong!
It has been repaired twice.
depends on the thickness of the metal. The recovery tank on my Big red unit lasted 20yrs before it started leaking.
don't know anything about the electrolysis, but you could eliminate all concern by coupling a full port brass ball valve to sch 40 PVC, then use a rubber coupler at PVC to tank outlet port
That's how Powermatics are plumbed.
Rubber coupler to 2.5" PVC to 2.5" brass full port ball valve to PVC nipple
Personally, I think those cheap plastic knife valves belonged on portys
Not a TMs.....
Keith
I haven't had a problem with mine... WAY easier to open then the pos pvc ones. I think I payed around 100 for it..
MerCrewser
got one, $31 at Lowes for 1.5 inch which is the size of the pvc on it now. No room to put pvc or buffer between, not even enough for a hose barb unless using a gate valve. My 12 yr old tank is in great condition, always has a few inches of waste water in it because pvc vavle is such a pain to use. I always run the pump out.
