Question: How do you know a pump is done?
Brevic offered a great suggestion years ago
make a QD adapter for your fresh water hose that will connect to the wand .
as long as the water is on in the joint, BAM...you can rinse
XTREME1
Ma
Greg Crowley
what about PSI
scratch that > was thinking off my fresh well and also I would like to be discreet
XTREME1 said:
what about PSI
the flow would get it done .
It's an emergency MacGuiver to get a job finished that doesn't involve electric and pumps ..which are little more than a stop gap measure for a crippled machine themselves
..l.T.A.
XTREME1
Ma
Greg Crowley
I agree that is why I wouldn't want a higher PSI than 200 that way it is still urgent but you can continue to work for days without disruption to the consumer except 1 power cord
Benton KY USA
You could change that pump in 30 minutes Greg.
Loosen the tension bolt near the pump drain.
Remove belts.
Remove two fittings: 3/4" inlet hose, and 1/2" outlet hose
Remove 4 mounting bolts.
New pump:
Attach 4 mounting bolts.
Reattach two fittings to inlet and outlet using teflon tape on threads
Put on belts
Tighten pump tension bolt
Check and fill oil
Pressure test for leaks
XTREME1
Ma
Greg Crowley
LEE YOU COULD CHANGE A PUMP IN 30 minutes. I can't even get the allen screw off
