one of the tuff things to dry is exterior walls if water ran down them from the top, because you usually have a visqueen moisture barrier right next to the drywall and then fire blocking which prevents getting air through holes at the bottom. IMO this is a rip out scenerio. headers above windows are also a difficult area, since its a window its likely to have insulation up there, the best bet is to make and opening above the window are tear it totally out so air can get up there. if its an interior wall that has OSB or stacked framing right behind the drywall and you are confident no insulation is behind it, I usually break out the perforation roller.
insulated ceilings really should just be pulled I have many times seen them test dry only to find spots of wet insulation above, believe me I HATE demoing anything, its time consuming, dirty and doesn't pay for shit. I have good luck drying non insulated ceilings, I have also used lay flat duct and taped it around an air mover put into the ceiling via a square hole and forced air up there, that works great too, not only does demo not pay very well, replacing the sheetrock doesn't pay either, I break even on sheetrock replacement.
the etes is a great tool however I only feel good using it in situations where it would suck replacing the item, case in point a sparkled popcorn ceiling area, that was furred down with 60's paneling on the sides that matched the entire basement, conventional drying I would have had to tear that stuff out, dealt with asbestos ceiling, and paneling that was long since out of production, again had to match what was in the entire basement. instead the etes dried it all out.
sometimes if I am not sure how something will dry I do what I think will dry it and if its still wet after 4 days of my best efforts it gets yanked, I also think the injectidry does not dry as good as just putting 1" holes behind where the base was and placing an air mover every 12 feet of wall space.
