Ready Derrick?
They think the carpet is faulty....
Let's see what the Cimex / Devastator can do to it
We did one like that and used Prochems Heavy Artillery shower fed through the Cimex. Flushed it with All Fiber Rinse.
Looked like new. Owner could not believe, they were planning on replacing it. That was over a heat ago, we've cleaned a couple of times since and it pops back each time.
Using the Cimex is an extra hassle but in the end a time saver and difference maker.
Reactions: Steve Lawrence
Prozyme plus and FWR.
Sounds like it will be dirty in a week again anyway unless you teach them how to mop tile.
Reactions: Jimmy L
Fabuloso?
"if it smells clean, it is clean"
Powerburst or any topQuality butyl 'n lye nuke juice
roto scrubbed and thorough flush/rinse extract with any quality alkaline emulsifier in stock tank metered at 2 gph
Or straight scrub n run encRap it with Cimex
add some Fabuloso to the encRap juice ....
Johnny
La-Z-Boy
Johnny
Flex CS 4 oz/ gal, red pad or micro-beast on orbital, Flex Ice. Post-encap with cotton pads if needed.
Restaurants don't want the fragrance.
Marty's right about you.
Reactions: Dolly Llama
DAT
Nevada
Bill Cheryl
Sure am. How could it be a faulty carpet? I thought it was typically for a busy restaurant that only serve breakfast and lunch...cooking bacon and sausage nonstop....
Wi
Keith
Powerburst and citrus pro..
What prespray and rinse would you use?
If you can't get it done with the prespray and scrub.. You are using wrong products! No rinse here!
