For those of you that have a Recoil and have had the issue of the 1.5" hose fitting on the bottom of the vac motor falling off......I found a solution.
I was messing with mine today and I noticed the third vac was not sucking so I knew the fitting came off again. Instead of using epoxy for the connection I scraped off the paint where the fitting touches the vac motor, then I used my belt sander and re-flattened the plastic fitting so there would be a good connection. I have this 3M double sided foam tape that was left over from my machining days, so I put a double layer on the bottom of the fitting and then stuck it to the bottom of the vac. The fitting is on there real good and does not budge at all.
While I was putting the machine back together........the other two fittings on the other motors fell off so I did the same to those.
