Just wrote about it Friday
RED WINE REMOVAL FROM LINEN AND COTTON
by Jim Pemberton - the Fine FabriCare Guy
<!-- display body -->
A fine fabric specialist recently asked me how to remove red
wine from both a white linen chair and white cotton couch.
(It must have been quite a party!)
A supplier recommended a strong peroxide based stain remover
that is designed for wool rugs.
While such a product may
work on wool with pretesting and care, there are definite
risks involved when using peroxide based stain removers on
cellulose fibers like cotton and linen, as well as some far
safer products & procedures to try first:
Strong peroxide stain removers often "overwhiten" and weaken
cellulose fibers. Before using such products, do the
following:
1. Make sure the customer takes full responsibility for
the issue, as what you are trying to do can bleach,
weaken, or distort the fabric. Get the understanding
in writing.
2. Spray the affected pieces with distilled water, and
while still damp, apply an acidic detergent like
Sapphire Scientific Natural Fiber Cleaner or
Bridgepoint TCU.
3. Brush the solution in gently, and then blot the
stained areas carefully.
4. If you see color transfer, continue to gently blot
(very gently...be patient) until you quit seeing any
color transfer.
5. Rinse with clear, warm (not hot) water.
6. Dry the fabric and repeat again until no more stain
remains. Often wine will come out completely with
acid detergents or spotters without the need to
bleach.
If the procedure doesn't work, allow the fabric to dry, then
apply distilled water again, and follow with a mist of
hydrogen peroxide (3%). Allow it to dry and see if you need
to go further. This takes care of wine stains without
resorting to stronger products that may over whiten and
weaken the fabric.
As always, the risk should be your customers', not yours.
If you would like some guidance on how to talk to your
customers about the risks involved when removing stains from
delicate natural fibers, look at the copy on the back of our
Upholstery Condition Report.
CLICK HERE
