My issue is that the one way valve at the and of the draw pipe that goes into the chemical (concentrate) jug, gets stuck (corroded- Procyon.) Therefore the mixed solution from the mix tank drains back to the concentrate jug.
Didn't happen much with other products, happens all the time with Procyon and Soap Free.
Its probably check valves on your chemical pump I went from brass to stainless steel used soap free and DFC105 and brass denigrated.
