you guys are full of it on a little tapping removing it, I had a
drieaz the one with the bone on the top for a handle and cord wrap on the back, this one had a plastic drum that had a few leauvers missing and caused a heavy vibration. I tried tapping all sorts of stuff, I used a ball joint pickel fork to stick down and contact the drum from the motor side to no avail, I ended up using a sawsall and cut the plastic spokes out of the drum, got it out of there and then the whole motor, now with the motor out I used all manner of beating, at this point I was so pissed I was ready to F something up, its a wonder I didn't beat the shaft out of it, NOTHING would budge it, finally I busted off all the plastic around the metal part that fit to the shaft, then I took a sawsall and cut this metal part lengthwise to relieve some pressure, even with a split down it, I still had to use a big ass hammer to get it off, infact it would not slide back on without some sort of press, good hell. I don't think
drieaz wants these to be able to be fixed, I am surprised the shaft thrust bearings are not f'd up, on chance of finding a new motor for these??
