everfresh1
:? How do you guys remove red dye stains with no power? Do any of you have A/C power outlet on you equipment?
everfresh1 said::? How do you guys remove red dye stains with no power? Do any of you have A/C power outlet on you equipment?
Dirk Wingrove said:Spray those suckers with Red Vanish while the carpet is still dry. I'm amazed at how many go away just by doing that.
everfresh1 said:Dirk Wingrove said:Spray those suckers with Red Vanish while the carpet is still dry. I'm amazed at how many go away just by doing that.
Who makes it?
Jim Nazarian said:everfresh1 said:Dirk Wingrove":161sbt8h]Spray those suckers with Red Vanish while the carpet is still dry. I'm amazed at how many go away just by doing that.[/quote] Who makes it?[/quote] [url="http://vacaway.com/vaRedVanish/index.htm said:http://vacaway.com/vaRedVanish/index.htm[/url][/quote:161sbt8h]
I just orderd some, I'll see how it work's. Thanks
Larry Cobb said:Jamie;
I have tested many, many brands of Red Stain Removers.
I have heard lots of discussion on results WITH & WITHOUT steam.
What I have observed:
IF the carpet has a quality stain-resist coating intact,
the stain can be removed without heat transfer.
IF it is apartment-grade carpet or does not have an effective stain-resist coating,
it will require "steam" to take out the stain.
Our one-part Dynachem Dye Stain Remover works in the same manner:
DC Dye Stain Remover Link
CarpetKING said:Buy an El Diablo built in generator - just run an extension cord and you are good to go. I'm gonna try the Red Vanish - sounds like a good product that I had never heard of.
everfresh1 said:CarpetKING said:I like the fact that you can run diesel instead of fuel-oil in the burner.
Spawn said:everfresh1 said:CarpetKING said:I like the fact that you can run diesel instead of fuel-oil in the burner.
I thought they were essentially the same??
( minus some engine additives and road tax on diesel fuel at the pump)
and burn K-1 kero anyway.
Much cleaner and no diesel stink
