residue on tile
I'm recleaning some tile tomorrow that has a gummy like residue on it. I applied a lot of citrus gel the last time and scrubbed it with a stiff brush then rinsed it. I guess I didn't get it all. Anyone encountered anything like this before? Its all that black stuff. I almost feel like taking a wall scraper to it first before applying any chemistry.
You can see the small area I scraped up pointed out by my keys.
Vivers
Bill
Probably mop & glo all over the floor. Really a nightmare and will need t be striped, then cleaned, then sealed. Charge for it as it's not your fault.
Good luck
You do know that is stone right Ron?
Bring some finish stripper with you.
Yes. Someone had a stone and tile online sem just before I cleaned it the first time. I believe he mentioned applying something to the tile. It was originally sealed after the first cleaning a year ago with a solvent sealant. I cleaned it, they sealed it.
Thanks
use a Malgirt brush or a Black pad under your 175 with the stripper, should come right off considering how flat the floor is.
I bought a citrus floor cleaner. Talking with the guys at the supply store and they were concerned about too high an alkaline on the stone. I like to err on the conservative side and I knew the citrus had cut it the last time.
I don't carry a 175 so I got a doodle pad, square black pad, and manually scrubbed it. Took about 10-15min of good scrubbing plus dwell time as I went back and forth to the truck.
Then rinsed it with the hand spinner. Couldn't feel/scrape any residue on the floor after I was done.
Between set up, tear down, going back and forth and actual cleaning, took about an hour.
You don't have a turbo hybrid or like tool?
Why did you use the hand spinner?
I had taken my Spinner out of the truck and forgot to put it back in.
Never use a 175 or pad machine other than a Cimex on the odd job.
Goldenboy
Mike Waldron
You have to realize the clown has removed 97 percent of the soil with a dry vac. Even Daniel can remove 3 percent of the left over soil with his POS Prochem.
Golden Boy
