Results of my Judson's O2 vs Power Max testing
floorguy
Doug
you cant see the REAL NASTY ones.....vs the cleaner ones???
if it had resoil issues, it would be a lot dirtier after a year.....right???
What's the correct dilution, Larry?
Marty;
I was just kidding.
2.5 oz./gallon is the amount you are using now (2 +1/2 oz.).
I like to test "dollar for dollar",
when I compare presprays.
PowerMax with a TM rinsing, does not have any resoil issues.
I do use an All Fiber Rinse for a baby-soft hand on the carpet,
if the rinse water is hard.
Larry
P.S. Nice photos Doug; showing year vs year soiling level
It cleans nasty tile and grout at 2 oz's per gallon too.
Just did one today.
Side by side test vs. Oxyblaster
Couldn't tell the difference between the two.
clean image
Carl Maddock
Ok, so what's difference between powder brighter and HP in 40 volume when addded to your tile and grout pre spray ?
I know even at 4/oz gallon, grout will efflores when it hits something organic
What would be equivalent in powder brighter ?
Powder Brightener is much stronger (22%);
compared to 40 volume (12%).
You only need to use about 60% as much (in ounces).
Larry
