Sticky
Do you guys think that I should have some of the walls sprayed with rhino lining when I have the floor done? If so how much or should I do all the way up the wall?
Should I screw 5/8 pressure treated wood to the floor and then have that rhino lined also or should I have the rhino lining put on first? Do you think that it is necessary to put plywood on the floor or is that just an "old school" thought that really wouldn't really benefit me that much becuase its going to be sealed?
Is there something that I could buy and spray on that would be similar or would it look bad and not work as well if I used a product myself?
(I don't think I will go that route but was wondering if somebody knows of a product that works well and looks good?)
Thanks for the help guys I just want to do it right the first time and these are things that will be really hard to change once the equipment is installed.....
