is there one type of rinse you use on both tile and carpet....or does everyone have to change there rinse jug over for each one.......
Shane T said:Along that line, how many gallons of water does it take to clear your system of one rinse and start getting the other out your solution line?
Lyman said:Jim, you are using stripper on the tile. Why not shut your chems off and rinse with water.
Blue Monarch said:I've never rinsed tile with anything other than water. If I did, I'd probably use HM's Clear Water Rinse, just like carpet. The reason....smells good and cleans up my QD's and jets. Seems to rinse alkalines pretty well also.
Terry said:so i take it none of you that are rinsing with water are applying sealer? I believe you have to neutralize for the sealer to adhere properly.
Terry
Terry
