Dolye and the gang want in on this rockin' Cleaner's Giving Back event!
First off we have....
4 x 6.5# Case of Blitz with GreaseBreaker –
This formula incorporates our famous solvent cleaning booster, GreaseBreaker, into a blend of alkaline cleaning agents and builders that quickly dissolves and emulsifies the heaviest of soil. Blitz is a non-enzyme mixture so it does not require long dwell times to break down the grimiest soil. This economical powder prespray will melt the grimy soil away right before your eyes. Being a super concentrate powder, Blitz will save you money. It dissolves quickly and easily. The versatility of Blitz with GreaseBreaker will allow you to effectively clean trashed and neglected carpets, as well as high soil environments like restaurants and dirty apartments. Since Blitz already contains GreaseBreaker, no other cleaning additive or booster is needed, even for the most heavily soiled carpets. The fast-acting high pH formula quickly dissolves the heaviest greasy soils. Unlike enzyme presprays that require extended dwell time, Blitz goes to work immediately breaking down and dissolving heavy built up oil based soling. Blitz with GreaseBreaker has a pleasant citrus fragrance that leaves a fresh clean smell to the room without being overpowering. It’s high powered alkaline RTU pH of 12.0-12.5 means it works well on neglected carpets. It is not designed to be used on well maintained, stain resist warranted carpets. At a use rate of only 2 ounces per gallon of hot water, Blitz is economical to use and super-concentrated. Blitz contains a perfect balance of surfactants, builders, and solvents for the compete cleaning job. It dissolves quickly and will not clog up sprayers.
Auction starts at $35 with a $5 minimum bid increment (free shipping)
Retail Price of $141.85 plus shipping
100% of proceeds go to RMHC
Auction ends January 30th @ 6PM PST
