Pro's Choice wants to help out as well, way to go CTI!
we have up for auction:
An amazingly simple vapor generator that is best described with two words, ”Performance & Economy”. This machine will match or outperform machines costing more than 10 times as much.
When working with Dry Vapor it is best to have distributed application so you won’t have high concentrations of vapor at the source and minimal concentrations at a distance. The VDT-4200 is ideal because it is inexpensive to place multiple units at a site and the VDT-4200 is very light and easy to attach to walls or set on nearly any surface. Add to this the fact that it runs on safe low voltage and you have a winning combination.
Specifications:
· Size: 4 X 4 X 15 inches.
· Weight (unloaded): 1 pound 10 ounces.
· Capacity: up to 12 dry vapor concentrate squares.
· Throughput (fan capacity) 40 – 50 CFM.
· Operating volume: Adjustable
· Power Source 115V to 12V converted
· Timer: External
· Vapor Source: Dry Vapor Squares and Dry Vapor Bars
Retail value $69.00
Starting bid $ 5.00 with a $1.00 minimum increment.
100% of all proceeds go to RMHC
Auction ends Feb 1st at 6PM pst
Specifications:
· Timer: External
Retail value $69.00
