- Joined
- Oct 6, 2006
- Messages
- 117,284
https://www.drieaz.com/DEC_Product_Base.aspx?decID=1028
The Grand Daddy of all carpet driers!
For years, you’ve been leaving wet carpet behind at every job, forcing your customers to tread carefully in their own homes. Sure the carpet is clean, but your customers can’t really enjoy it for hours after you leave. But it’s just the nature of carpet cleaning, right? WRONG!
By the time you leave, your customer could have a house full of clean, dry carpet! It’s possible thanks to the Dri-Eaz Studebaker AirPath, an incredible air mover specially designed to dry carpets fast. The 360° outlet grill blasts 40 MPH of warm, dry air straight down and across the entire carpeted surface, allowing you to dry one room while you move on to clean the next one!
Plus, you can use the AirPath on more than just carpet. Lock the wheels and use it to dry tile,wood floors, or other hard surfaces in minutes. Flip it on its side and dry stairs in no time!
All proceeds from this auction go 100% to RMHC.
Payable by check only, made to out to Ronald McDonald House Phoenix
Serious bidders only. Prizes will be sent out directly (at no charge unless noted, from the donor once you check has been received by me.
Opening bid is $300 w/ minimum $20 increments
Retail value is $595
Free shipping to the lower 48
Auction is over September 24th at 6PM PST, highest bid wins at 6PM sharp.
