Jim Martin said:all depends on what rotary you get.............
GeneMiller said:if the rotovac is truly needed then it is faster then the wand .
gene
Ron K said:GeneMiller said:if the rotovac is truly needed then it is faster then the wand .
gene
Even if you use a 175? You know the old 2-Step!
GeneMiller said:we used the 175 and wand verses the rotovac in the same house same size rooms and the rotovac not only was faster but it did a better job with less sweat.
we only use the rotovac when needed because it's definitely slower when it's really not needed.
gene
