Rotary Tile Brush
PTMatt
Roseville, Ca
Matt Martinez
Does using a tile brush attachment on either a 175 or the 360i save you from having to manually scrub grout lines? Have a big tile job tomorrow and was wondering if one of these attachments might save me some time.
Dallas, Texas USA
Matt;
Assuming you prespray, have a TM with good heat and flow . . .
yes, the 360i hard-surface head will do a good job of cleaning the grout lines.
The brush has abrasive impregnated into the nylon for added agitation.
The 3M segmented brushes with abrasive are fairly good on a 175 machine,
but lack the hard-hitting washjets.
Larry
GeneMiller
Boca Raton
gene miller
i used to scrub everything years ago but i don't find it necessary. i had the original steamway tile tool with tiny jets but once i installed 04's i didn't need to scrub anymore. i think it originally came with 01's or smaller. i have the turbo now and it blasts just fine at 1100 psi. i still scrub the edges under cabinets.
gene
PTMatt
Roseville, Ca
Matt Martinez
gene
I've tried not scrubbing on a few jobs before but it just seemed like I wasnt getting the same results. I currently use the SX-12 with my Butler.
My local supplier sold me the Tampico brush for my 175. Anybody use this? Seems like the brissles are kinda soft for tile.
Johnny
La-Z-Boy
Johnny
Albert Lazo said:
The best brush I've found was John's op brush on the conqueror.
Albert
I use that brush on a Brute. Works better if you strap a little weight on it.
I still use a pole brush on every job.
Brian R
Little Elm, TX
Brian Robison
Is it that pet clinic?
GeneMiller
Boca Raton
gene miller
if you need to scrub every job to get the results then i would suggest a change in your chems. i pretreat a large area and then start. occasionally i have to retreat a bad area but it's rare. i use powerbreak from bridgepoint with oxygen bleach as a boost .
gene
PTMatt
Roseville, Ca
Matt Martinez
gene
I tried not scrubbing today and it came out Great! Just boosted my chems a little. Man it saved me alot of time!
Gonna try the Powerbreak with oxygen bleach as boost. Thanks Gene
