juniorc82 said:
I gotta say that the rotovac cfx isnt all that to thomas. What you gain in portability is lost by things like lack of a chemical injection, also what does your cfx do for you in a house that is winterized or the power and water is cut off? There are no silver bullets in this industry we do the best with what we have available to us(for most of us owner ops). I would like to also say that cylindrical brush machines are garbage. Get a 175 rpm scrubber. You cant beat all the applications a 175 can offer from brushes to bonnet pads from carpet to hard floor applications. I think a 175 should be a mandatory device for any porty operator. Oh ya I clean hardwood floors with my 175's good luck doing that with a whitiker or an op machine. dude get a good porty and a 175 you are not gonna beat that combination for your needs and price.
Lets review what the duel cord, CFX power pod, can do.
It sucks up waste water and continuously and automatically disposes of it.
It does this amazingly well...at 50' to 100'.
It continuously pumps waste water away at 6 gpm or 360 gals per hour.
It can accept 2" or 1 1/2" hose.
It can function as a Vac Booster/Waste Disposer by connecting 2" TM... or whatever hose... to its exhaust...which is designed for it.
It weighs 40 lbs...is 2' tall, 18" long, and 13" wide!!!
The CFX power pod is not all that...but as someone who owns one and uses it...its pretty damn close... :wink:
It does not have anything to do with supply water...only waste water.
Rotovac does provide you with every adapter to connect to house water...and the hoses to do it.
I solved my chemical injection problem by having Brevik build me a "tool box" sized 170 psi demand pump...which also solved my "pressure", sprayer, and potential lack of hook up in older buildings issues...it weighs approx 6 lbs.
In Washington... we get the PM or owner to turn on the water and power before we do the job..."dead" houses are not a big part of my business... :wink:
What do Porty operators in Missouri do when they don't have water and power???...haul buckets from the river and suck on the end of the hose...
Hey Jon...you got an auto fill and auto dump on that Recoil?... or are you part of the Bucket Brigade???... :wink:
Do you have to stop cleaning to fill or dump?
Continuous Flow Extraction....is faster.
The CFX could be improved...less taper in the top housing portion would allow replacing the high performance 5.7 vacs with high performance 7.2 vacs...adding only about 1.5 amps per leg...the impeller in the pumpout is made of hard rubber and is subject to wear...no problems so far...but its screw driver easy to replace impellers...and they give you extras.
I am looking for the tools that will give professional results and I want them to be as light and powerful...easy to store, deploy and repair ...as possible...light enough for a woman to use by herself. I have achieved that in my selections except for the the 85 lb Pad machine. BTW ..I clean hardwood floors with my Pad Machine...in fact I could refinish hardwood floors with my Ocillating Pad/"sanding" machine... :wink:
Really would like a folding, "baby" Hos Orbot, 15" (50lbs) with weight kit....
