- Joined
- Oct 22, 2012
- Messages
- 28,253
- Name
- Ron Marriott
Must have been some sermon.Can we all agree that HWE is seriously needed with puke in a pewAlso a good
portable wet vac is a plus as well![]()
As you own the copyright to idiot, you may not use the word moron. you have to leave some of the disparaging words for us common folk.All of you morons are stupid
How would you know what type of backing it has? Is HWE best for commercial glue down carpet?Wicking is becoming a thing of the past with today's commercial carpet tiles that have a rubber backing. When the HWE process is properly done, how can anything possibly wick up? I never get callbacks on that type of carpet that's replacing the old commercial
It appears I used my Rotovac 360 and itleft wicking. Not sure if the dials work. They appear to be very easy to turn and not set properly on a church carpet. Had to go back and wand. Good thing it was just a small area I tested. Any recommendations? I have never VLM'd.So I am thinking I need a RE machine. Last year I cleaned a middle school (medium size private) and then got the got the church also. They do not want vlm and who am I to argue. I only HWE. I am doing the church again and they let me know they want it done every 6 months now and the school once a year. I’m done wanding the entire place. It’s not too bad on the light/medium soiled areas. But the heavy soiled areas are a beating. I started looking at the Bentley Pro but I don’t know if that would be that much quicker. Im considering the Rotovac 360xl or the T-Rex. I do very little commercial as of now. Those that are doing larger commercial jobs, what are you using? Seems like you can find good or bad reviews on all of the machines.
Most, if not all of commercial carpet tiles have a rubber backing. Carpet tiles are squares of carpet.How would you know what type of backing it has? Is HWE best for commercial glue down carpet?
DITTO!I have both the Rotovac 360XL and the Mytee T-Rex. They are both great machines.
When I bought my 360XL they gave me a Mikey's Board discount and upgraded my motor to a 3/4 HP. I use the nylon brush head with teflon glides. You can not adjust the speed on the 360XL, but I almost never get any hop out of it. If I do get hop it's because my handle is out of adjustment and is causing me to hold it awkward. I do one wet pass and then come back dry. My dry times are excellent.
With my TREX it comes standard with 1HP motor and adjustable speed. I have 3 different style heads for it. With proper speed adjustment and head selection I eliminate any hop. The only down fall to the TREX is not having an adjustable length handle. I'm 6' and it's a tad short to my liking. Dry times are also excellent.
I just did some rotary extraction for a commercial account that needed some serious TLC. I bid it at $1.00 a sq ft. They were so blown away by the results they scheduled reoccurring cleans.
The rotary extraction not only cleans the best, but it is an impressive presentation. I posted a video in a local FB group and it got a lot of attention and I booked several jobs from it.
When I use rotary extraction it's so much easier on my body and I'm way less fatigued.
The downfalls are that it is slower. You have to be disciplined or it's very easy to overwet the carpet. It's really sucks to use in any space that's not wide open. You'll use more water.
I hope this helps you make a decision.
You need to equip yourself with an orbital like a Trinity Phoenix and learn to use products like Saiger's code red of encap or similar and do a demo for them. There are lots of guys out there using rotaries and crap chemicals that give VLM a bad name. A good quality oxy-encap will wipe out coffee stains easily. Much easier than trying to treat with hwe.Apparently the last 2 companies before I got the account were doing vlm. They didn’t want a quote if i wasnt going to HWE. I guess that’s why they called the O/O one van guy. Guess everyone else was smart enough to turn down HWE on a large church. Besides the soil from foot traffic there are lots of spills. Probably 100-200 on the lower main floor alone. Lots of French vanilla coffee. They tell me the vlm cleaning never really got it clean and spots were never really gone. I used approx 250 gallons of water to clean the lower floor alone. Very large church.
Hogjowl, what are the challenges with RE on loop pile commercial? Does the machine typically not run smoothly on loop? This carpet is loop.
The speed dial is for smoothing out the operation on commercial carpet. On most residential you go at full speed. On commercial you adjust the speed down if you experience chattering on the carpet. Teflon glides make it much smoother. Glue down carpet cleans up great with proper VLM. I often choose VLM over my truck mount unless it's a restaurant or something really nasty.It appears I used my Rotovac 360 and itleft wicking. Not sure if the dials work. They appear to be very easy to turn and not set properly on a church carpet. Had to go back and wand. Good thing it was just a small area I tested. Any recommendations? I have never VLM'd.
I just sold my Rotovacs. I haven't been using them since I got my CRB. Great machines for trashed carpet but that's not my market anymore. The CRB works great on the odd one I get these days.I have 4. Two 360's, a hoss, and the rx-20. Great for trashed but too uneven on most commercial. Go with the zipper and learn vlm. I don't do much commercial but that's what I'm targeting next year.
Nice find, they are about $700.I found a 360 brush head laying on the ground outside my friends house when I was looking for the cobra I loaned him. haven't used the 360 in years but I want to try it out on the next nasty.
