Danny Strickland
anyone have and USE one to do furniture cleaning? Pro's/ Con's of the machine if you have one.
Don't let the compact size fool you. The CFX has dual 3 stage vacuum motors and a great auto empty pump out system.I think they rent those at the grocery store. WELL not exactly like it, the one at the grocery store is much powerful.
Danny,is it heated or just need 2 cords for the vac???
The CFX would work for those two situations. For the office upholstery work you would hook an upholstery tool directly to the faucet in the kitchen or bathLooking at doing warrentee work for Guardsman and maybe some commercial upholstery in Dr's offices etc?
for the warranty work you could carry in a battery sprayer with a QQ hookup to the upholstery tool.
I'm just saying he could use the CFX if that's what he had. You could bring in some half-assed machine and do a half-assed job and be done in half the time. But this is a serious setup to do serious business.Art you're working far too hard. I'd be done cleaning and you'd still be setting up.
If it were a days worth of cleaning, yes that would be the better choice since you can clean upholstery nonstop.
Oh, not loving thatDanny,
The CFX is only the extraction part - the water comes from somewhere else, either a faucet or separate pump.
The point is, it's a modular system. You separate the pump and vacuum into easily carried sub 50# units. To get comparable power in a self-contained unit you need to load and unload a 150# machine. Not fun by yourself, not bad if you have a chimp. But then you have a chimp with you all day who's only purpose is to help lift a heavy porty. That's pretty wasteful and expensive.Oh, not loving that
That's where you trade off cleaning too. You'll be more productive and not as worn out at the end of the day. A two man crew is only good if they both work. Hiring a hose holder is as you stated an expensive proposition.That's pretty wasteful and expensive
I have the two cord 3 stage CFX that I bought used a year ago and have used it on hundreds of jobs. The standard one cord model would be enough for furniture cleaning, I'm sure. It's is the best moduar unit available and does exactly what I hoped it would. You need to put an inline vacuum filter on it like a Devastator or a Lint Hog because the sock filter in the machine will quickly fill up and the APO won't work. Once you figure out how it all works it's a perfect system for carpet and upholstery and tile (with an electric 1200 psi pump).
Hi Art-- I was thinking about buying a CFX as a backup too. one of my vans cant fit a full sized porty. but is the fauct water presure a little weak on carpet? If you use water pump then I take it you would need 3 separate outlets? How much did you pay?
Art, nice set up. Have you ever tried this with a 360 I believe it would kick but in that situation. Also two people can always stay busy if you know how to work. Prep/Vac, move furniture/tab,block, pre-condition,groom move air-paths apply Scotch Guard ext.
Warm water, weak extraction.
You could probably do a good job if you take your time and UP the agitation and spike your prespray on carpet.
It's nice that you're emptying into a toilet and pulling off the sink. Does that mean you can keep cleaning until your scum bag/filter is full? If so, GREAT for a upholstery tool like the HF or SS.
The current crop of RE's are actually designed to use lower pressure, like the 360 with it's floodjet-type jets and the Hoss's spraybar and flow control orifice. I think one of these modern RE's would be a great fit for a CFX/hot water tap connection, and of course low pressure lends itself well to upholstery, though you may have to adjust jetting to get the flow you want.
