RotoVac CFX
Art Kelley
Well, it's smarter than running a TM with a #3 blower. This dual 3stage CFX has the same CFMs (230) as a #3 blower TM but you bring it up to or into the jobsite giving you drier carpets than your old TM did.
I'm so proud that you hacks never give up. Even in the face of humiliation you just keep going strong trying to figure out a hard way to do a simple thing.
My hat is off to you!
Reactions: hogjowl
dgardner
Dan Gardner
Well, not really - due to the way cfm is measured for a centrifugal fan vs. PD blower.....
This comes up a lot, and I'm not sure I've ever seen a comparison graphed out - so here goes. I picked a 33 blower (wimpy) and a pair of fancy new 8.4 Ameteks in parallel (super powerful!) to give the electric vac's the best chance of showing up that poor PD blower. Using the numbers the Ameteks (280 cfm) appear to handily beat the #33 (195 cfm). Here's what it looks like:
The two are equal only if you limit lift to 2"hg - after that the electric vacs are toast. The Ameteks only beat the PD under basically free flow conditions - no wand, no hose, just an open inlet......
Under actual use conditions PD blowers are still king and will be for the forseeable future.
dgardner
Dan Gardner
As long as I hijacked this thread I might as well add one more tidbit. Since I did the above graph I figured it would be interesting to add series Ameteks to compare them to parallel. As you can see, as your operating point moves to the left the parallel vacs win, as it moves to the right the series vacs win. Interesting (the blue line is an approximation using the 60%rule). The PD still beats them both either way.
dgardner
Dan Gardner
19 pounds? Wow that would be easy to move around for sure.
With a pop up handle too and storage wrap for the hose and solution line.
If he's only working on spots and not trying to clean the whole piece, I would think this would serve him well.
At less than $600.00 I might buy one. :biggrin:
Hey Daniel whut bout somthin lik dis? :biggrin:
Not my choice for over all cleaning a piece but if you're only doing warranty work 3-gallons should do you. ???
http://www.hyorelequip.com/EDIC-339MH-HT-Bravo-3-Gallon-Heated-Spotter-with-Hand-Tool-Kit_p_245.html
Without heat. For that price I'd just carry your own hot water in a 5-gallon jug and pour it in.
Roll up, hit the spot and leave. :cool:
http://www.hyorelequip.com/EDIC-300MH-Bravo-3-Gallon-Spotter-Extractor-Machine-Only_p_244.html
best spotter on the market.
ordered one for a custy/friend 10-12(?) years ago.
he uses it for spotting between regular cleanings (three dogs, and two cats..one that pukes a lot)
he also uses it to clean the upl and carpet in his motorhome
great machine
Rob really does have difficulty with what he seems to perceive as potential idol competition. That's why he ran Jim Martin off.
