Rotovac Heads
joey895
Joey J.
Unscrew each of them in the same direction they rotate during operation. The two heads screw off in opposite directions.(the left head is reverse threaded). I just lay the machine back and use the heel of my foot to give it a sharp hit downwards and it just spins right off.
Farenheit251
Sharp blow w/ a rubber hammer on the vac slot opposite the way it normally spins or use a wood block and a hammer. If done frequently your heel will work. If it has been a long time trying getting some oil in there. Brian E
Darin
Thanks
It came off fairly easy. Guess I was making it harder than it needed to be.
Scott Rogers
Dont forget to pull the 2 small vacuum hoses off and clean them out too. they can easily get plugged.
