rx-20 problems
J
JR
I have an RX-20 and I am not getting power from the handle. Has anyone had problems like this before? I think it might be the trigger switch.
replace the cord.................
take the back panel off where the cord goes into
take a picture (if you are not use to working with this type of thing)
so you can remember how it is wired and go buy a cord of the same size (14 gage) and replace
I would not think it is is the switch...........they have a pretty tough micro switch n the inside and unless it falls off a moving truck or has a major short.........
this switch should out last the RX..........
A
alazo1
I had this happen and was a loose wire. Start with plugging it in with an extension cord in the motor section and go from there.
Albert
J
JR
rx-20
I plug in the motor at the base and it worked fine. So I know its a power issue not making it to the motor. I removed the switch but I am going to try replacing the power cable next if you believe the switch is that good.
A
alazo1
Hey JR, do you have a continuity tester?. I hardly knew how to use one but I more or less learned when I had your same problem. Now that you know the motor is good you can go from there.
I believe the parts you mention are fairly inexpensive so even if they are good it wouldn't hurt to have them around.
Maybe someone can chime in and give a very brief explanation of how to do this.
Albert
W
wired
I had this problem to and the handle was not making connect with the switch that is right next to the handle . take off cover and take a look. I am having problems with the handle staying in place when using it. Handle pops loose and the machine takes off. I have tighten metal bare and this helps for a while. Any thoughts
W
wired
Greg Loe
Take a meter and test voltage at end of power cord.(not the end that plugs in to the wall) If no voltage, replace cord
Latest Auctions
