bahrahm said:which rotary machine should i buy between these two any of your thought?
Mikey P said:Not yet Zee.
I'll have one to play with in a month or so but the 1st 170 or so units have been spoken for
royalkid said:RX-20 Has proved itselfs over the years...might want to wait and see what bugs get worked out of the Hoss? Why go with a machine that "might" clean as good as the RX-20? I'd be worried being one of the first to get a machine like that until the verdict is out.
juniorc82 said:so what is the 360i chopped liver now?
Jim Martin said:I have not had the chance to use the Hoss as of yet so I can not say how it does...........but.... I can tell you that I have been leaving the 360i on the truck more and pulling out the old RX......and have been much happier with the results.....
Art Kelley said:[quote="Jim Martin":224kzpmx]I have not had the chance to use the Hoss as of yet so I can not say how it does...........but.... I can tell you that I have been leaving the 360i on the truck more and pulling out the old RX......and have been much happier with the results.....
George III said:I no longer use rotary extraction tools.
Jim Martin said:the 360i is way to low to the floor.......on the thick..higher pile carpets it leaves bad streaks no matter how you try to change the cleaning pattern....personally I think it is because once the TM fires up and the suction pulls it down into the higher fibers and does not allow the jets to disperse like they should...on the CGD's and berbers..the teflon supports keep it up of the floor and it leaves no streaks...
this picture was taken on a CGD......look at the clearance.......and how the teflon supports hold it up.....
on a thick one it will not hold it up they just suck down in....
Mikey P said:Billy said:The comparison competition I saw this year at M-Fest didn't go so well for the Hoss IMO.
Billy, I can't help but think that you were aware that that particular beta machine was not the final production version.
