Saiger’s “Cide” Sauce Lime Citron Odor Destroyer
We started with a simple goal to develop a true odor eliminator that would leave behind a light pleasant scent and positive impact with our clients.
After extensive research, we’re excited to introduce
Saiger’s “Cide” Sauce Lime Citron – the latest technology in odor destruction!
It absorbs, modifies, destroys and safely eliminates the worst odors from Urine, Vomit, Skunk Spray, Garbage, Must/Mildew, Smoke, Sewer backup, Organic decay, Cooking odors, and many more…
Pleasant odor elimination has finally arrived! Give it a try…your clients will thank you!
DIRECTIONSPrepare a solution of 8 oz. per gallon of water (1 part of
Saiger’s Cide to 16 parts of water) and flood the contaminated area sufficiently to soak the surface where the odor may have migrated.Wait 10 minutes dwell time; if possible allow to dry before cleaning.If the cleaning will be done at the time of treatment, apply product to the dry carpet prior to any cleaning and re-moisten surface fibers with
Saiger’s Cide after the cleaning.
General malodor of carpet, pet accidents:dilute up to 4 oz. per gallon of water and spray the surface evenly and allow to dry before using.
Pet bed, upholstery and mattresses treatment: dilute up to 6 oz. per gallon of water and spray mist the surface of fabric and brush gently and allow to dry before using.
General Cleaning solution: dilute up to 2 - 4 oz. of
Saiger’s Cide per gallon of cleaning solution and proceed with normal cleaning to eliminate odors and freshen up areas.
ULV fogging: 4 oz. per gallon of water
A Great addition to
Saiger’s Sauce 1 Free & Clear unscented!
Fragrance Boost to Pre-spray: Hydro Force Type Injection Sprayer – Dilute 2 to 8 ounces of
Saiger’s Cide per 5 quart container with your
Saiger’s Sauce Free and Clear (or prespray of your choice). It will give a very Fresh Lime scent with odor eliminating capabilities.
Pump up or Electric – Dilute 2-4 ounces per gallon of mixed cleaning
Saiger’s Sauce 1 Free & Clear (or prespray of choice)
