Village Idiot
- Joined
- Jul 13, 2011
- Messages
- 26,354
Up for Auction:
Our goal was to make Encapsulation simple and effective. We spent time testing and creating two encap products to take care of your Low Moisture Cleaning Needs. Both Saiger's Encap products are wool friendly.
The Saiger's 2X Double Strength OXY Encap (The Code Red of Encaps) is a peroxide based product at a 4-5 pH, and is great for those office cube farms or Churches and Celebration Facilities. It will take out Tannin Stains and Soils effectively and efficiently. People also love it's gentle scent which is it's own natural scent. Bring your sunglasses, as it really makes the carpet "Pop Alive" as it dries.
“The Code Red of Encap Cleaners” is a concentrated highly effective low pH cleaner, with the power of Peroxide and our revolutionary encapsulating polymers. The peroxide helps with organic stain removal, odor removal, and helps to make those fibers colors “pop” with brilliance! The Encapsulant captures the soils, rounding off the soils jagged edges, and coat the carpet fibers for easier soil removal. This highly effective encapsulant also helps to coat the fibers to prevent re-soiling and wicking of stains. The Polymer will dry to a crystal for continued easy soil removal. This is a very Low Odor product with a very light fresh scent during cleaning.
pH: 4-5 pH
Directions:
1. Depending on Soil level dilute using the following guide for mixing:
· Light – Medium soils: 3-5 ounces per gallon of water
· Medium – Heavy soils: 5-6 ounce per gallon of water
· Extreme soils: 6-8 ounces per gallon of water
2. Pre-spray carpet (or Shower feed) and work in with your cleaning unit (Bonnet, OP, CRB, Cimex, 175, hand mitten) The product will dry to a soil encapsulating crystal once dry.
3. You may vacuum when dry.
4. For hot water extraction, prespray, agitate as normal and extract using Saiger’s Deep Blue All Purpose – All Fiber Rinse (or an acidic rinse agent).
The Saiger's 2X Double Strength Encap (The Blue) is more for those crazy factory, manufacturing plant, greasy type cleaning situations. It's an 8-9 pH with a light Mango Citrus Scent.
Saiger’s Sauce Encap 2X Double Strength Encapsulant Cleaner is a concentrated highly effective 8-9 pH cleaner, with revolutionary encapsulating polymers. The Encapsulants help to capture the soils, round off the soils jagged edges, and coat the carpet fibers for easier soil removal. This highly effective encapsulant also helps to coat the fibers to prevent re-soiling and wicking of stains. The Polymer will dry to a crystal for continued easy soil removal. This is a very Low Odor product with a very light fresh citrus scent during cleaning.
This product is effective with Color Fast wool (test for color fastness) and synthetic fibers. It may be used on fine fabrics during upholstery cleaning techniques. Pre-testing in an inconspicuous area recommended with any fine fabric.
For use with Bonnet, Rotary OP, Counter Rotating Brush, Cimex, 175, hand scrubbing or as a prespray for Hot Water Extraction. Can be used with a shower feed or as a pre-spray. (Helpful Tip: We recommend rinsing out your shower feed systems after use to prevent encap from plugging up the system) This product works very well when using absorbent pads for immediate removal of encapsulated soils.
Ph: 8-9 pH
Directions:
2. Depending on Soil level dilute using the following guide for mixing:
Light – Medium soils: 2-4 ounces per gallon of water
Medium – Heavy soils: 4-6 ounce per gallon of water
· Pre-spray (or shower feed) carpet and work in with your cleaning unit (Bonnet, OP, CRB, Cimex, 175, hand mitten) The product will dry to a soil encapsulating crystal once dry.
· You may vacuum when dry.
· For hot water extraction, prespray, agitate as normal and extract using Saiger’s Deep Blue All Purpose – All Fiber Rinse (or an acidic rinse agent).
(If the videos work for you, here is one showing me cleaning with each product. I have not done just a promotion video for each at this time…)
Oxy Encap:
View: https://youtu.be/QKXX7qoZN3k?si=sJd28b7wJkB9sA0Z
The Regular Blue Encap on a manufacturing facility:
View: https://youtu.be/tjb1Ks-UrbY?si=49vzoCX_qF5lKgsu
- One 4 x 1 Gallon Case of Saiger’s 2X Double Strength OXY Encap (The Code Red of Encaps) Retail value: $172.58
- One 4 x 1 Gallon Case of Saiger’s 2X Double Strength Encap (The Blue) Retail Value: $148.94
- Free shipping to lower 48
For use with Bonnet, Rotary OP, Counter Rotating Brush, Cimex, 175, hand scrubbing or as a prespray for Hot Water Extraction. Can be used with a shower feed or as a pre-spray. (Helpful Tip: We recommend rinsing out your shower feed systems after use to prevent encap from plugging up the system) This product works very well when using absorbent pads for immediate removal of encapsulated soils.pH: 4-5 pH
Directions:
Ph: 8-9 pH
Directions:
Oxy Encap:
Total Retail value plus free shipping to the lower 48: $327.52
Starting bid $240
Minimum bid increment $2
Auction ends Thursday March 7th at 9PM EST/6PM PST
Starting bid $240
