Introducing 2 of our Newest Products! Each of these has been in testing and development for the past 3 years. We are finally bringing them to the market and to Mikey's Board for a Premier Release Auction.
This Auction will feature:
(Info about the new products)
Introducing Your New Go-To Solution for Pristine Surfaces!
Saiger’s Sauce Multi Surface "Pro Cleaner" is the ultimate choice for professionals who demand exceptional performance on LVT, LVP, stone, and other hard surfaces. With rigorous field testing, we’ve crafted a cleaner that delivers quick drying, residue-free results, and effortless soil removal.
Key Features:
and achieve professional-grade results with ease!
We started with a simple goal to develop a true odor eliminator that would leave behind a light pleasant scent and positive impact with our clients.
After extensive research, we’re excited to introduce Saiger’s “Cide” Sauce MANGO Citrus Odor Destroyer– the latest technology in odor destruction!
It absorbs, modifies, destroys and safely eliminates the worst odors from Urine, Vomit, Skunk Spray, Garbage, Must/Mildew, Smoke, Sewer backup, Organic decay, Cooking odors, and many more…
Pleasant odor elimination has finally arrived! Give it a try…your clients will thank you!
DIRECTIONS
Pet bed, upholstery and mattresses treatment: dilute up to 6 oz. per gallon of water and spray mist the surface of fabric and brush gently and allow to dry before using.
General Cleaning solution: dilute up to 2 - 4 oz. of Saiger’s Cide per gallon of cleaning solution and proceed with normal cleaning to eliminate odors and freshen up areas.
ULV fogging: 4 oz. per gallon of water
A Great addition to Saiger’s Sauce unscented cleaning formulas!
Fragrance Boost to Pre-spray: Hydro Force Type Injection Sprayer – Dilute 2 to 8 ounces of Saiger’s Cide per 5 quart container with your Saiger’s Sauce prespray of your choice. It will give a very Fresh MANGO Citrus scent with odor eliminating capabilities.
Pump up or Electric – Dilute 2-4 ounces per gallon of mixed cleaning Saiger’s Sauce prespray of choice)
- 2 Gallons of our new Saiger's Mango Citrus Cide Odor Destroyer - Retail Value $94.04
- 2 Gallons or our new Saiger's LVT- LVP Multi Surface Pro Cleaner - Retail Value $46.06
- One 6.5 pound Tub of Saiger's 10 Below Powdered Pre-Spray Retail - Value $46.17
- One 6.5 pound Tub of Saiger's Sauce 1 Powdered Pre-Spray - Retail Value $43.71
- One 6.5 pound Tub of Saiger's Free and Clear Powdered Pre-Spray- Retail Value $43.71
- One 6,5 pound Tub of Saiger's Code Red Powdered Pre-Spray - Retail Value $53.59
Key Features:
- pH Level: 7-8, ensuring a balanced and effective cleaning.
- Concentrate: Ideal for professional use, offering unmatched versatility and power.
- Dilution Recommendations:
- Light to Medium Duty Cleaning: 2-4 oz/gallon
- Medium to Heavy Duty Cleaning: 4-6 oz/gallon
- Quick Drying: Prevents residue and streaking for a flawless finish.
- Water Spot-Free: Advanced chelating agents ensure no unsightly water spots.
- Effective Wetting Agents: Penetrates deeply for thorough cleaning.
- Safe on Multiple Surfaces: Perfect for LVT, LVP, ceramic, porcelain, hardwood floors, and more.
- Odor Eliminating Fresh Scent: Enjoy a light, crisp herbal aroma that effectively neutralizes odors.
- Cleaning Flexibility: Suitable for use with flat mops or hand wiping techniques.
- Mixing:
- Combine Saiger’s Sauce Pro Cleaner with water at the recommended dilution ratio:
- Application:
- Apply the solution using hand sprayers, pump sprayers, inline sprayers, or flat mops.
- Cleaning:
- For deep embedded soils, increase agitation with CRB, Rotary, or appropriate pad.
- Mist the solution onto the surface, allow for dwell time to suspend soil, then wipe or rinse clean as needed.
- For stubborn stains or heavily soiled areas, increase agitation and ensure proper dwell time for optimal results.
DIRECTIONS
- Prepare a solution of 8 oz. per gallon of water (1 part of Saiger’s Cide to 16 parts of water) and flood the contaminated area sufficiently to soak the surface where the odor may have migrated.
- Wait 10 minutes dwell time; if possible allow to dry before cleaning.
- If the cleaning will be done at the time of treatment, apply product to the dry carpet prior to any cleaning and re-moisten surface fibers with Saiger’s Cide after the cleaning.
Total Auction Value with Free Shipping to the lower 48: $327.28
Starting bid $225
Minimum bid increment $5
Auction ends Monday December 9th at 9PM EST/ 6PM pST
Starting bid $225
