daniel@procarpet
- Joined
 - Sep 7, 2008
- Messages
 - 3,797
I have to bid on a floor that I inspected today.
Same thing I have seen several times.
I know it is hard as hell to get the wax off the floor so really I need advice on the best approach.
When you apply stripper and start scrubbing the floor becomes real muddy and you are essentially spreading the clay around. The problem is the floor is so red and muddy that you think you have all the wax up but you don't. There is usually some wax that is embedded or it needs to be re-stripped. Now the floor is so porous that when you apply stripper again it soaks in pretty quick and just makes the whole process harder.
I could turn the pressure up and rip the wax right off, but I would be afraid of leaving swirl marks.
Anyways the job is 350 sq ft of saltilo. I do have a very stiff concrete brush and I could use some black strip pads.
What is the best pressure to use and how many times does it usually need to be scrubbed? Also someone mentioned something about sanding.
I would like to get 800 dollars for this job,but would be willing to go 700-750 if I had to but no lower than that.
Any input would be appreciated.
