Tried the new Saphire today on microfibre.
light weight, nice feel in the hand, nicely balanced, easy triggering
very flexible hose with good length. (I want one for my HK tool)
Dislikes:
left the fabric wetter than the HK
VERY Noisy, twice as noisy as the HK
uneven spray, you can see this in the video. I'm not really convinced the jet pattern is the best for an overall cleaning.
sucks in the fabric too hard, makes it harder to pull along the fabric than the holed teflon glide of the HK
You can see it really grab the material in the vid.
the trigger lock would not lock with pressure in the line. That's what I was trying to do in the video just before I showed the spray of the HK. With the water pressure off, the tool would lock, but with it on, it wouldn't.
If I were to tweak this, I would make the trigger lock easier to work, able to work it with one hand.
I would change the jet system to make it flat like the DM tool and make the vacuum slots into holes with a thin slot after the holes to avoid the lines left by the HK tool's holes.
I'd use teflon as well, slides much easier than the plastic.
Two biggest flaws with the HK are the line left in the fabric by the holes and the weight of the tool head. It does flush the fabric better, esp for a stubborn spot, and it leaves the fabric dryer.
I'd love to blend the two, take the best of both and put them in one.
Overall, had I bought this tool, I'd be very disappointed. Against the HK, it doesn't keep up.
Had I bought this without a comparison, I'd probably work with it and think it was doing a good job.
Dislikes:
