Nampa Carpet Cleaning
After 2-3 years of heavy use my SS Upholstery Pro finally broke. The stainless steel braided line @ the connection. I still have the original ''flexible" vac hose and it just didn't have the structural integrity for the 370. The hose got hot, twisted then the vacuum would suck it in as the head of the tool was on the fabric therefor putting pressure directly on the SS braided line. I use to run the tool with a propane burner on my last TM also so I am sure that didn't help.
I think SS should add a piece of reinforced rubber tubing to the outside of the braided line before they press the fitting. That would help make it last longer. I have used this tool a Lot. It was new from not long after it first came out. I use to use it on stairs for a while too. You can't expect it to last forever. It is an excellent tool. I will order the new parts asap. Until then I have my Prochem tool. Overall I give it a thumbs up.
