Saugercide is a BOMB cleaning booster
GeeeAus
Grant Baverstock
Title says it all. Fair shithole job this AM. Mixed some Saigers into my oxygen powder. Stuff actually cleans well in its own right.
Loves me Saigercide.
Put some in your shit today!
87067
87068
87069
87070
two kinds VLM'ers in general
Those that know it's limitations and can rationally discuss pro 'n cons
and the brain washed nincompoops that have been convinced fairies wear boots
Hal said
"you joined a support group that specializes in a method you say doesn't work"
spiddy senses suggest....
you could possibly have a conversation with Hal
Donno about Garry
all I see is blistering butthurt
Reactions: Wand Slinger
PEEE-AZZZZZ
why would any pro that knows shieet from shine-ola frequent a VLM only group?
Info on gear or revalOOshunary juices ?
or to get heartburn and high blood pressure over stale baloney and hyperbolas nonsense served daily ?
OR.... stir the koolaid with a dirty stick for fUn and spOrt
87089
GeeeAus
Grant Baverstock
I genuinely do use low moisture myself. Its a good tool. I like being able to do it well. So I read and don’t usually say much.
But I do see the lop sided thinking at times and feel a duty to honesty.
I don’t normally descend into name calling.
But I’m not really your mate if I let you walk aroubd thinking you can vacuum the shit from your bonnets because the soil has been encapsulated and can now vacuum away.
Now there’s a logical follow on to this inconvenient truth.
If it doesn’t vacuum from the pad ...
I’m being sincere with you and the VLM group when I say I buy that it improves appearance. I also don’t observe resoiling is a problem. But the soil does not vacuum away... because otherwise cleaning pads would cacuum clean and they don’t.
The facts are that it only leaves a DRY RESIDUE.
Years ago someone did the vacuum test after encapsulation/scampoo and found NOTHING in the vacuum bag.....................NOTHING.
It has always been about the marketing BS
You do it to make easy money
Reactions: Dolly Llama
That's because the crystals are so fine, they pass through the vac filters and dissipate into the air. Like magic.
But did you look with your microscope?
