sweendogg
- Joined
- Jan 15, 2008
- Messages
- 3,534
- Name
- David Sweeney
The Great Oz said:I can understand the use of solvent carried protectors on water-sensitive upholstery since you obviously don't want to add water.
I'm trying to understand how using an OMS carrier can make the same fluorochemical better than if it was carried by water.
It certainly makes it a boatload more expensive to use.
Brian the only thing I could potential see as a positive is that the oms based is not goint to be absorbed as easily as the water. So you get an appropriate curing time.
Just my .o2 cents!
