bob vawter
Grassy Knoller
- Joined
- Sep 15, 2007
- Messages
- 44,617
- Name
- bob vawter
Any Omar the tent maker size...?
That was my ideaPutting the shirts in bags with their nametags was genius. See, Meg, what do you need me for?
See, Mike, what do you need me for?That was my idea
To hold him up? He pats himself on the back pretty hard.See, Mike, what do you need me for?
Lots of that going on...
To fix your punctuation? Oh, yeah, that’s what I thought you said.To complete my harem..
Jim....that is the worst case of pig Latin I've ever seen.....hep an uncluthed out here a little ..."Honi soit qui mal y pense"
Or perhaps identify them?"In French, Honni soit qui mal y pense is often used ironically, to indicate hidden evil intentions"
So many nuances and calques when idioms get translated."In French, Honni soit qui mal y pense is often used ironically, to indicate hidden evil intentions"
Huh?So many nuances and calques when idioms get translated.
I do like that handle
Kinna good huh?Just stick to being a Bible critic Bob.
Only one of you Bozos that uses the
I do that all the time. I usually keep the handle just a little taut so I can adjust itOnly one of you Bozos that uses the
Handle correctly!!!
And if you loosen and rotate that handle counterclockwise about 15 degrees you will have the famous "sidewander"
Try it
Full trigger?I'm a lefty so handle is bit shy of 2 oclock
X2… you and me both Dan…I'm a lefty so handle is bit shy of 2 oclock
