Less residue than rinsing with water!
New
All Fiber Rinse will completely change how you look at extraction rinses. It
cleans BETTER than your favorite go-to detergent rinse yet
leaves less residue than even a
water rinse.
If you already use All Fiber Rinse (bottle) and
All Fiber Deep Clean,
here’s how NEW All Fiber Rinse is DIFFERENT - it applies unique technology that cleans better. New All Fiber Rinse can even attract and remove soils and residues from previous cleanings – a breakthrough unmatched by any other formulations to date.
One of a kind
New All Fiber Rinse uses
next-generation chemistry -
Residue Release Technology! It has a strong attraction to the soils and minerals that cling to carpet fibers, but it ISN’T attracted to the fiber itself. PLUS, it binds the soils and minerals (called agglomeration) - even tap water minerals – for easy removal and a
residue-free feel that’s
super soft. And it
stays cleaner because less residue results in less resoiling. Plus, it has a stable 4.2-4.5 pH, and a light, customer-pleasing fragrance compared to other acid rinses.
This is an industry-first, high-performance rinse!
You will be astounded to see how our hydra-coating technology allows All Fiber Rinse powder to
dissolve quickly and completely - and
stay clear - in both hot AND cold water. It also doesn't clog filters and jets like some powders do. All Fiber Rinse has other great benefits, too - it’s non-corrosive to copper, brass, and aluminum, helps prevent scaling and mineral build up and its cost-effective powder formulation makes up to 30 gallons of RTU solution.
