Scrub & Recoat on Asbestos Tile
Doug Rice
Looking at a job that is in a government building or I wouldn't really worry about it. I usually just do a wet top scrub and re coat and all is well. This place is a pit and it needs a lot of work but I would never strip it. How aggressive can I get? Do I need a HEPA vac or scrubber? I plan to charge a lot or I will walk away.
warm water, neutral pH and a brown pad under a 175.
Rinse with your hard surface wand @ 300 psi
Onfire_02_01
Jeremy Gray
Keep it wet and no problem with any asbestos. I will use a black stripping pad under my 175 when I do a scrub and recoat. That way I can get the same agitation while moving faster.
Doug Rice
Thanks for the help, I will take a bid in today but I doubt they will pay what I want. Now I have some official rules on how to handle this that I can show a customer.
W
Wiley Gordon
Stripping and waxing does not do anything to disturb the asbestos fibers in the tile. While u do have to be certified to remove the tile floor, even then it's not very friable.
D
dgardner
Seeing as how the work is in a government building though, I understand why Doug wants his ducks in a row.
Reactions: Lee Stockwell
