Scrubbing carpet with tampico brush & swing machine.....
BUSY BEE
....does anyone use this method after prespraying to agitate/scrub the carpet?
I use my floor machine with stiff nylon bristles on the apartment/rentals, but it may be too aggressive for residential, so I'm looking at a tampico brush. I don't believe in the RX-20 and use this method, I'm curious how the tampico bristles hold up on carpet.
Thanks, Bill
tman7
Tacoma, WA
Tony Gillihan
Is this the kind that you have used? I was thinking of getting one and thought it would be acceptable for most residential, especialy Olephin. Of course only for the real nasty ones. But mabey I should go for something softer on Residential.....
http://www.cleanfreak.com/Qstore/p001094.htm
BUSY BEE
I don't have that one, looks interesting being that it has 2 different types of bristles though. I don't know the exact type or name of mine. The nylon bristles aren't super stiff, they have some flex, but could do some damage on certain residential carpets. Works great on olefin, gotta kinda lean into the machine with yer hip to keep it steady, but that beats scrubbing forever with a wand. But a Tampico is soft, ideal for certain residential carpet, just not sure how the bristles will hold up.
Dallas, Texas USA
Bill;
A Nylon brush should work fine for residential carpet.
I've cleaned many of them with a fairly stiff nylon rotary brush.
Make sure the carpet has solution on it.
Larry
CleanFreak.com
Appleton, WI
CleanFreak.com
A tampico brush would work, but it definitely would not stand as well as this carpet brush. You would definitely want to break the carpet brush in before using on residential carpeting. A good method to break these carpet brushes in is to run them for 10 minutes on cement before using on carpets. This will help to "tip" the brstles outwards, as well grounding any possible burrs off the ends of the bristles which may have been created during the manufacturing process.
BUSY BEE
Thanks guys.
I'll stay with the one I have and see how it goes on the next residential.
Bill
Brian R
Little Elm, TX
Brian Robison
Isn't the middle part of that brush adjustable to create more or less agitation?
I used to have one where you raise the bulb up and down and worked really well.
That was a Chem-Dry brush.
CleanFreak.com
Appleton, WI
CleanFreak.com
Brian,
You are correct. It is an adjust-a-glide riser in the center there, so you can adjust the agitation. You can also raise it as the bristles start to wear down.
Thanks,
Tim
