Apr 30, 2012 #1 D dan mabes Guest What would you use to seal a concrete floor that had a cat urine smell? Dan M
Apr 30, 2012 #4 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 31,225 Name Larry Capitoni what Kevin said Shellac based sealer ..Zinsser BIN is the best ..L.T.A.
Nov 23, 2012 #5 Jim Nazarian Member Joined Oct 7, 2006 Messages 741 Name Jim Nazarian Is Pro's Choice Odor Barrier a clear product? Does it change the appearance of concrete in anyway? (Unfortunately concrete will not be covered) Last edited: Nov 23, 2012
Nov 23, 2012 #6 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Name Larry Cobb Dan; We use an acrylic solvent-based Concrete Sealer. It has very good adhesion & barrier properties. http://www3.cobbcarpet.com/zen3/ind...arch_in_description=1&keyword=concrete+sealer It can also be recoated. Larry
