Leslie Judson Jones
- Joined
- May 12, 2007
- Messages
- 2,242
During our recent reengineering of a truckmount with an aluminum recovery tank, it came to our attention that the tank has developed a substantial amount of electrolysis corrosion. This tank is a little over 4 years old. If you have an aluminum recovery tank, this is an issue you need to address.
Our suggestion is to scrape the electrolysis off the inside of the tank and treat the inside of the tank with a mild acid like an aluminum wheel brightener from an auto parts store. We also recommend that you attach about 6 anodes inside the recovery tank. I will post a link to a place where you can purchase them.
http://www.westmarine.com/webapp/wcs/st ... assNum=422
This is a very serious issue that needs to be addressed if you have an aluminum recovery tank. Electrolysis will pit through an aluminum recovery tank about 4 times faster than if the tank was just made out of carbon steel and rusting.
