So I ran it all day yesterday with the stat installed like pic 2. Arrived to first job with room temp water. Fortunately for me it was just a sofa/loveseat that was barely dirty. I only had a couple of minutes between jobs so I didn't have time to do much but I did put some card board in front of radiator and it did run the van temp up, it held at right at 210 all the way to the job so I thought maybe I was good. Started the job and had hot water, reading about 180-190 at the gage. A few minutes into the job I noticed the water was not hot anymore and it stayed cool the rest of the job. When I noticed the water was cool I felt the heat exchanger. The upper half of the exchanger was hot and the bottom was very much cool. This morning I just let the van idle in the driveway for about 30 minutes and same thing upper part of heat exchanger hot and lower cold. I thought that meant air in the system so I opened the bleeder but got liquid out immediately, no air. Oh and part 46 is I believe a white magic add on. The water outlet that the top radiator hose hooks to sits on top of that part. That nipple on part 46 has the hose that runs to the top of the heat exchanger hooked to it. There is a hose teed off from the lower radiator hose that runs to the bottom of the heat exchanger.
