eco-clean said:
The main issue with sisal is shrinkage and it will keep shrinking any time you add water.
How much water do you put in, Harry? How deep?
Cold water?
Any issues with shrinkage?
Any "Halo" effect due to use of reducer?
Also sisal is very easily damaged by scrubbing or even light rubbing. It scratches really easy!
[quote="Harry Myers":27qgwsp6]Depends on the sisal . Different constructions sometimes make it easier to clean. I clean alot of sisal with vomit, piss and etc. You could have tried some ammonia mixed with water , detergent and blot then a vinegar water mix. Alot of times you have to use a reducer to lighten it up and speed drying is most important.
Cold water?
Also sisal is very easily damaged by scrubbing or even light rubbing. It scratches really easy![/quote:27qgwsp6]
The procedure up top is a (spray on with triggure sprayer), Blot with white cotton towel.
I've taken a 5 gallon bucket and poured on the sisal to flush out with my claw.
Then many times I pit washed them . I used host also before .
I always had sucess with the reducer, lightly keep misting until achieved result.
