Slotted glides are the ticket
FastEddie
Ever think of the fibers getting sucked up into the slot, hot lava water flowing and saturating thru them? Hole glides only seem to have very little of that, very uneven like. So holes are easier to push and dry a little quicker, slots clean, remove debris, and straightens out the fibers much better, in my opinion. If you have so much trouble pushing a slotted glide, you have overkill vacuum for single wanding, which forces you to use holes.
yep, I concure with your findings, Speedy Edro Supemo
Holes just don't clean deep enough on cut piles, IMHO
You're guessing.
I can turn DOWN my vacuum to test..
Can you turn yours UP?
But you haven't so your just guessing.
Until you and meAt have felt the rush of a 6008 blasting through those holes you'll never know.
FastEddie
Yeah but think about it, those holes can only suck up so many fibers, the ones that don't get sucked up is what I'm talking about.
With my slotted Ti wand, I am getting a little over 1 hr dry times, when I do use it, and it's not that hard to push. I have the right amount of vac with my overdriven 45, Bayco valved.
Eddy, you should see what's in my waste tank.
With a V, holes work just fine.
Trust me.
FastEddie
I believe you, but what I really meant was a slot glide sucking up fibers, without removing them, standing them straight up before the big flush, something a hole glide couldn't do nearly as well.
"Until you and meAt have felt the rush of a 6008"
Most don't.
"You're guessing. "
Not with my system
Most don't have a 68 blower ya mow-ron.
But I am starting to think maybe I should.
Do you have Shawn's phone number handy?
...L.T.A.
