So I am on vacation and the guys overfilled the waste tank. The float was bypassed many years ago so it shut down on it's own. They emptied tank and restarted. Put wd40 in blower lube ran it for a few minutes then started pump. Water came out of unit and wand but not at full pressure. Any suggestions?
this has been confusing from the get go....it may be eaiser to figure out if we can get clearer information....being your on vacation and getting everything 2nd hand I am sure is not helping you....( or us )..............
tank over filled.....got it....
float was bypassed year ago but it still shut down...what do you mean bypassed..??......if you bypass it then that means it is not working and it should not of shut it down...the high water level should of been picked up by the blower and pushed out the exhaust.........
emptied tank and re-started.....got it....
I am assuming that they sprayed WD40n in the lube port....stuck red straw in port...did not try it with out red straw so it did not go all over the place....and maybe get on belts....
but lube port should be on front of machine (?)...and belts should be protected behind panel (?)....
Water came out of unit....where.....??...I know where it is coming out of the wand....
going off the lack of info on this.....seeing how the 2 are not really tied together.......
off the top of my head....did they start the pump with machine fully ramped up.....???........if so they may have spun/glazed the clutch.........
