So if you were handed........
All the resources that you ever needed to build your own carpet cleaning rig..........How would you build it
type of truck ..type of machine...what would you make/buy....any special quality's you would build into it...
with everything at your disposal......what would you create....
Jim;
Odin has the right Idea.
I'll post some advance pictures of the....
brand new 2009 prototype tomorrow....
Jim, you WILL like the heat capability.
It does require a box truck.
P.S. James - I have a carbureted Nissan 4-cyl. with a #5 blower sitting on my showroom floor.
"P.S. James - I have a carbureted Nissan 4-cyl. with a #5 blower sitting on my showroom floor."
ChemSpec 860?
AshleyMckendree
Ashley Mckendree
AIR POWERED ENGINE
With a Bio-Diesel/Electric Air compressor to keep it charged.
Spinning a Roots 47 at 4000 rpm, with max flow in/out, going to a ROUND tank - with no baffles.
I think it would suck like a 2 dollar.... wHortex :twisted:
vincent
Vincent Sapp
I would take a co gmc with a low profile custom box to Judson and let him have his way.
Direct drive, remote control, remote line hook-ups on the rear and side, plenty of fresh water holding capacity, big waste tank (tall & thin). Clear top like the ups trucks, plenty of lighting inside and out.
Now thats what ya call CFM; I was a test cell operator for 2 years at NAS North Island ran all jet engines at AIMD.
ODIN said:
be]http://www.youtube.com/watch?v=korIZ3YynHk[/youtube]
how about a v12
i]http://www.youtube.com/watch?v=EXEdq3UnnFE[/youtube:1dmruz7i]
handdi
Randy
how bout this
electric truckmount that charges while you drive to your next job
cat pump
large blower
could call it pirusmount
what ya think terri
305 chevy driving independent machined cds with twin 59 blowers in paralell with kero heater, 4000 psi independent driven pump, 2.5 inch plumbing throughout, pimped 2" greenhorn wand, all in the back of a box truck.
Let's see: Chemspec TM
1. Nissan Carbureted Engine - reliability
2. #59 Blower with spline shaft coupling
3. General Pump
4. Water-to-Water Heat Exchanger- time proven design
5. Exhaust to Water Heat Exchanger -SS Diverter
6. 4" Plumbing out of blower (greenie's favorite)
7. Hypro Clutch- Drive Pump-Out
Which component is not 1st Quality?
At least, it wasn't built in Calif.
Curtis Pennington
Steven Hoodlebrink said:
[quote="Larry Cobb":35nrwrkz]
The truckmounts made in Wichita Falls are much better.[/quote:35nrwrkz]
EZ now calm down...
OK, here is the picture I promised:
Turbine Powered TM
Greenie should like the high flow plumbing on this one.
Chrome-plated starting system.
AshleyMckendree
Ashley Mckendree
Turbine Powered TM
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Where is the blower, How many HP is this?
Jay D
My next truckmount when and if i get a helper to dual wand with. 38hp air cooled Kohler, overdriven 56 tri-lobe blower with 4" plumbing in and out, Stoddard silencer, General Pump 5 gallon per minute pump, Exhaust heat exchanger OR 4ht propane heater, Mytee waste tank, 300 ft electric hose reel, 2 -14" 1.5" green glided wands, Long wheel base Chevy van. Of course I CAN build it myself but I would rather Santa Claus bring me one some Christmas. :D
What is that?
I see a power inverter, and some serial ports like an old monitor hookup?
The part marked HX, how does that serve as an exchanger?
Is that Aluminum that it's all bolted down to?
What is up with the transfer pump?
Turbine Powered TM
Ashley;
Horsepower is 50-60 dependant on fuel flow.
Blower is centrifugal just like a turbocharger.
P.S. Jay - I like your specs, but you don't want a Tri-Lobe (less CFM)
I would like to see someone build a TM using rubberband technology.
V
Vinnie
A Judson TNT, and tell Les to build it as if he was building it for himself.
You guys are something more power, more horses.
Remember were cleaning a peice of nylon 1/8of a in. long how much more power do you need.
It's like trying to catch a mouse and using a Laws Rocket.
MerCrewser
Its not so much power for me. I just want a reliable powerplant that will last 10 years. Thats why I always liked the Nissan Prochems. Has anyone ever had to do anything other than change the oil in one of these? I only tuned one up once. They jut loaf along at 2500 revs or so depending on themachine theyre in and run forever, 10,000 +++ hours.
B&BGaryC
With unlimited resources, I would buy Jeff from Greenglides, and take him down to the Vortex factory with me.
I'm sure if I got Rothschild rich I could purchase a human being against their will.
