Meter Maid
The Undetective
Why are my outside jets working but not the inside jets?
I cleaned the inside jets and still nothing.
But it literally just happened.Throw another set on it and put the old ones in a bath of descaler. Probably hard water deposits clogging the jets.
at 7pm on Jan 1st?But it literally just happened.
5pm American time.at 7pm on Jan 1st?
Sure but it happens. More often in areas of hard water or without a water softener.But it literally just happened.
I have an onboard softener.Sure but it happens. More often in areas of hard water or without a water softener.
Great, you got much further down the road than other guys.I have an onboard softener.
You should know.So did this guy have a meltdown every time a “perp” didn’t comply?
No. How?Did you flush the manifolds?
No criminal record as a stand up adult citizen unless you think of a few random ticketsYou should know.
Yeah, because it’s just a miracle.Should’ve kept that Devistator
Figured it out!How?
Jhfc...
FO, what did I day in the first post?Figured it out!
Thanks, as always for your warm advice...
douche canoes
ShhhAnother reason to have a minimum 2flow size jets. Anything smaller gets clogs.
No. How?
