Doug Cox said:I believe its Parflex, not Synflex.
I would have to say the same thing as meAt, except I have only been using Parflex for a little over 4 years now. I have 65' as my lead hose, and 200' of ineptune in 50' lengths.meAt said:never used Synflex
but have been using Parker for 17 years or better, if that tells you anything.
it will be stiff and curly as hell when you first get it.
after a month or so of use it relaxes .
It will never be as flexible as Ineptune, but is lighter and not near hot to touch.
No "instant" failures like ineptune either.
The outer jacket will blister and develop pin spray leaks when it's kaput
Nate The Great said:meAt said:never used Synflex
Then you just cut off the damaged part and have someone recrimp with a new fitting right?
Speaking of which, I have 3 50' lengths of paraflex I got in a deal. The coupling on the end looks to be corroded on the inside and whatnot. My question is, Is it worth it to cut off about afoot and recrimp? Does the hose itself get clogged up? The hose itself looks to be in good condition. $15 per side to recrimp is what I was quoted.
everfresh1 said:Nate The Great said:meAt said:never used Synflex
Don't you guys use the screw on ends instead of crimping them? They are reusable just cut off the damaged part of the hose and unscrew the end and then screw them back on. Hose fixed. No crimping needed. You need a cutting wheel to cut the line cleanly though.
screw on ends? I never seen those. Sounds pretty good though, you got a pic and place I can get them from?
everfresh1 said:screw on ends? I never seen those. Sounds pretty good though, you got a pic and place I can get them from?
You should be able to find them at any power washer supply store you screw the base into the hose counter clockwise then you screw the end into it clockwise simple, :mrgreen:
think" those might be steel braid hose, Jamie?
Parker and Synflex are plastic.
do they make 'em for that type too?
lance said:Larry Cap, how much do you think it costs to be able to crimp Parker hose at home instead of taking it to a shop?
How often do you have to recrimp the hoses you use?
I'm not sure but i think the "screw on" ends are only for emergency use UNTIL the ends can be crimped just like the factory does it.
