Jul 6, 2007 #1 J Johnnyone Member Joined Oct 8, 2006 Messages 185 How much HP does a solution pump really use?
Jul 6, 2007 #2 C cmaster Member Joined Oct 7, 2006 Messages 477 Location Canada Name Paul Budnik It should be in the specs for your pump. Do you have them? The manual should be on the manufacturers website.
Jul 6, 2007 #3 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 31,225 Location North East Ohio Name Larry Capitoni depends on the pump and and what PSI it's running at. At 450psi, my Cat 5CP doesn't use a heck of a lot of HP. I'd "guess" less than 2HP When ran at 1500 psi, it needs more ponies ..L.T.A.
Jul 7, 2007 #4 J Johnnyone Member Joined Oct 8, 2006 Messages 185 It a GP pump rated at 3.5 GPM. The hp required at 500 psi according to the manual is 1.4 HP. Which seems to be minimal load on a gas motor.
Jul 7, 2007 #5 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb John; That's the actual HP required for the pump. The blower takes about 90% of the HP required (13 to 14). Engines should only deliver about 70% of their rated HP continuously. Larry Cobb
